configure ldap domain delete server
configure ldap {domain [domain_name |all]} delete server [host_ipaddr | host_name] {server_port} {vr vr_name}
Description
This command is used to delete one or all LDAP servers from one or all LDAP domains.
Syntax Description
domain_name
Specifies the LDAP domain from which this server is to be deleted.
all
Specifies that all configured LDAP servers are to be deleted.
host_ipaddr
Specifies the IP address of the LDAP server to delete.
host_name
Specifies a DNS hostname of the LDAP server to delete.
server_port
Specifies a port number for the LDAP service to delete. The default port number is 389.
vr vr_name
Specifies the virtual router to delete.
Default
If a domain is not specified, the server(s) under default domain is deleted.
Usage Guidelines
None.
The following command deletes the LDAP server LDAPServer1.sales.XYZCorp.com from the domain sales.XYZCorp.com:
* Switch.8 # configure ldap domain sales.XYZCorp.com delete server LDAPServer1.sales.XYZCorp.com
The following command deletes all LDAP servers from all LDAP domains:
* Switch.8 # configure ldap domain all delete server all
This command was first available in ExtremeXOS 12.5.
Platform Availability
